After first assembling my kit i had problem with the K8400 missing steps causing the prints to go bad after a few layers.
Accepting the the first defeat i ended up reading alot about how to properly [color=#40BF40]align the xy-carriage[/color].
After reassembling the xy-carriage and then enlarging the distance between the clamps i got the printerhead to move with almost no friction,
as long as i are moving the opposite side of the rods(at the clamps) equally. Moving one of them to much/little so that the rod no longer is
perpendicular will increase the friction a lot so that the the rod have to be readjusted to become more perpendicular to allow further move.
Is this normal or have i enlarged the distance between the clamps to much? I felt that friction when moving the rods was to high before
enlarging the gap this much.
After attaching the belts and adjusting the rods to be as perpendicular as possible with only a digital calliper (about 0.1 mm difference).
I then moved the printerhead by hand, and both in x and y axis i feel that the friction increasing about once ever 100mm, after that distance
it become easier to move again, and then again after about 100mm the friction increase again. Turning on the power and stepping movement
from the controller show the same behavior that some areas have more friction that others. The friction as about the same in the middle as
towards the end of the rods, its just some parts during the movement the friction increases.
Another thing i noticed will trying to troubleshoot the printer lately is that when i move the printer head in x or y axis i can see that the clamps
are moving up and down very slightly just like if the rods are a little bent. Is this normal? or could it be that the rods Velleman delivered
was slightly bent causing me all this trouble?
