If someone would be able to shed some light on to the failure mode of the K8200 printer I run at work it would be greatly appreciated:
Brief history
Originally built by a colleague 1 1/2 years ago (who has now left hence I am the new custodian, I changed the nozzle which improved prints immediately which gives you some idea of how much it is being used)
Fan track blown (I think since original build)
Used almost daily (working days)
Running windows 7 with RepetierHost_84 with latest drivers CDM v2.12.00 WHQL
Printer stopped running prints - Run print and nothing - extruder was being heated though (Print bed runs off of work bench power pack)
Was able to move one of the steppers but nothing would print despite printer saying it was connected
Decided to re-install everything (which i did on 2 PC’s of a similar spec. just to make sure)
I discovered that all but one of the stepper motor drivers were at around 0.125V (which may explain the slipping I have been encountering)
Re installed drivers CDM v2.12.00 WHQL Certified
Re installed software RepetierHostK8200_0_95F
In both cases the printer will now not connect at all n.b. I have checked basics like baud rate COM port etc…
Throughout this process I have had a suspicion that there is a more fundamental problem as when the printer is connected LD6 (Green) LD5 (Red) are constantly on and reset and or attempts to connect the printer do not change this, I remember this not being the case before the failure to print and now connect problems began.
Actions I am considering
Update the Firmware (although I am unsure how to do this, and have not easily been able to find out how to do this)
Replace the board
Question
Can anyone tell me what the failure mode is before I embark on more drastic action.
Any support would be much appreciated.
