It seem to be not possible to print ABS with my printer.
The printer is not heating up to 245 C. By blocking the fan I have been able to load ABS , but the printer is not printing on 230 C .
Also unload on 245 C is not possible.
I’ve had the same issue.
It turned out that the temperature sensor was not correctly placed.
When you place the sensor you have to feel if there is a blob, i used one of the solder blobs instead of the sensor.
You should check if your sensor is placed correctly.
Best regards,
Danny
