When we buy this printer arrives mounted. But when I connected to PC, give me the next error: “NO SIGNAL DETECTED, FORCED START” and don’t work the printer.
While I’m in the program Repetier, I configure the printer and I connect it and when I press Print, don’t work, tell me wait 25 minutes and remains freeze.
I think the problem is the printer, because don’t turn on.
I hope a answer!!!
Did you connect the 15V power supply correctly and checked if the correct Voltage is present?
Did you make sure the connection settings in Repetier are :
Baudrate : 250000 baud
Transfer protocol : Auto detect
Reset on connect : disabled
Receive cache size : 63
cheers,
Christian
THANKSSSSS!!
Does that mean it works now?
Yes it works! THANKS AGAIN
Nice to hear!
Happy printing!
cheers,
Christian
Worked for me too!
Thnx
