The printing quality of the vertex 3d printer is great. But it’s really hard to detach objects from the glas plate without destroying the surface and the printed object. I’m using PLA. Do you have any suggestions to overcome this?
you may need to calibrate the Z axis (move it away from the print bed)
Some times I will use canned air.
Turn the can upside down and spray the project.
This will cool the project and make it a little easier to remove.
