Last piece printed was also hot and easily warped when finished, something that never happened before.
EDIT:
Measured the resistance of the thermistor in room temperature (25 degrees) and it was 80 kohm. The printer says its 30 degrees when turning it on.
I’ve tried twisting and realigning the thermistor with the same result.
Obviously, you’re overheating your filament. Stock values are too high but yours look sky high. Try lowering the temperature to 190° (PLA) and the flow to 70%.
Should be spinning 100% of the time IMHO
It could be you lowered the percentage it runs on to low so it doesn’t run at all. (set @ 50% I think it doesn’t move at all)
Did U try a new nozzle? Could be U made the nozzle hole to big by cleaning it. And now its not continuously extruding any-more or something like that? Like oozing all the time. Could U make some pictures of the Nozzle? Maybe someone can spot something that’s off by that?
Well maybe, try some different filament? Some other colour? Next thing that comes to mind… Did you connect the small fan correctly? Like it should be blowing towards the nozzle not blowing upwards.
You said it started with swapping in a new PTFE tube…
Well try that again maybe? Start from the things u know have changed. Also check the feeder? Is the toothed feeder pulley maybe a little lose?
You are in front of the machine, its not that easy to give more advice than already given.
But like Raby mentioned before
Bottomline is: The print becomes to [u]hot[/u] at some point. That’s the only thing that’s definite.
I only saw something happening similar when printing a cylindrical tube upright (size of a pen) and the layers hadn’t had the time to cool down and started to show the same kind of dripping as in yours. By adding a forced air-stream right underneath the nozzle I managed it to continuously spiral print that.
Does the overheating theory apply to the Vertex logo as well? To me, that one is slightly different, it almost looks like the nozzle is digging in to the top layer and cutting groves. But there are also the small “blobs” on the side of the Vertex logo, which could be an indication of overheating?
To get to the root cause why this is happening I think its important to investigate a number of theories.
Overheating
Manually setting the printer to say 10 degrees lower than the melting point of the PLA. If the temperature regulation is correct it should not be possible to manually push through filament.
Printing a single wall, large diameter cylinder would also revile how the print is progressing temperature wise.
Z axis jammed or underpowered
The grooves cut into the Vertex logo got me thinking that perhaps the Z axis is not running as smooth as it should.
This should preferably be tested using a micrometer clock gauge, moving the z axis in 0.1 mm increments.
Firmware settings
When I did my successful prints I had not modified the settings of the printer what so ever.
A factory reset or and / or reinstalling latest firmware is easy to do.
Things I have already tried
Changing the temperature sensor thermistor
Repositioning the temperature sensor thermistor
Changing the print nozzle
Cleaning the heater block in acetone overnight to remove any PLA debris
Printing models with exactly the same gcode that has worked before
Setting the fan speed to 100% for the entire print
U have checked polarity of the fans?
Measure the crappy vertex logo thickness and see if that is somewhat what it should be.
Otherwise like u mentioned the Z stage is not running smooth like it should be… Could be your printing on the same level multiple times.
Try to manually go up and down and see if every 0.1mm step it actually drops/raises. If it is jumpy that could be the cause to.
