Hi Guys,
after a break of nearly one year I am back again and trying to get my k8400 to run. So I downloaded the velleman keychain file and here is the result:
I am using MatterControl on Mac OS X with 1.75 PLA at 190°C.
- The print Layer Height was 0.1mm
I used some settings from the board and
- changed the Retraction Speed to 110mm/s
- Retraction Length to 4mm
Whats the maximum speed for good results?
Is this a good result and how can I get better results within the bridged area?
Any suggestions?
I tried to make some bridge tests but i wasnt able to determine the correct settings for good results. I will show some pictures later when I’m back at home.
