Print profiles?
Where does one find the printer profiles for quality settings other then 0.1mm? Like for example 0.05mm and 0.2mm…
Or do you need to experiment and test trying to creating your own?
[quote=“nicksegers”]Where does one find the printer profiles for quality settings other then 0.1mm? Like for example 0.05mm and 0.2mm…
Or do you need to experiment and test trying to creating your own?[/quote]
You create your own.
Basically nothing else changes. You’ll perhaps have to fiddle a bit with the first layer extrusion width.
You just add them in the Cura config. Click on the little+ sign and choose one. I did this for 0.2 and it seemed to work perfectly without me changing any of my defaults.
