Hello
Is it possible top print hotter for the first layer? I cannot find a setting for that.
Regards Tommy Fer
Hello
Regards Tommy Fer
You can change the generated g-code
Add this command before 2nd layer :
M104 Sdesired_temp or M109 Sdesired_temp
Command M109 wait until temperature is reached
or use a different software like Simplify 3D (not free)
Thank you
That would be a solution. Maybe it is possible to make a script
[quote=“SlowFoot”]Slic3r engine has a separate setting for temperature on the first layer and a lot better control on fan speed (It also has a time/layer setting that can slow down your prints a lot).
.[/quote]
Yep, you’re right. I missed this.
