PPS10 software
Hey,
Any idea where I could find the software for the PPS10?
and will this device work with the PCUSB6 cable?
Thanks.
It can be found on the downloads page of our website.
http://www.velleman.be/downloads/files/downloads/pps10_rev1_1_1_78.zip
Should work with USB to RS232 converter.
Ah yes, just found the software page (well hidden, it felt like finding waldo… :p)
Thanks for the quick reply, and it seems to work with PCUSB6 just fine.
Anyone tried with the Aten usb->rs232 cable?
aten.com/products/productIte … 2316346005
I haven’t managed to get things up and running.
Operating system=Vista.
Dear support center!
I can’t bye recommended USBtoRS232 converter. Please email me the electrical demands to RS232 interface for proper operation (voltages & currents for correct operation of optocouples in the PPS10 interface cable).
Thank You.
Unit is compatible with standard RS232 signals.
There are no opto-couplers in the PPS10 interface cable.
hello all,
I see this thread here is long time not active anymore, but I hope somebody could help?
may I first introduce myself a little
I´m car technician, own shop since 35 years, working on all kind of cars.
since long time I work with the VELLEMAN PPS 10. now a friend of mine told me that I could connect the osci to a computer. so I connected the cable ( one side goes in the osci, the other side has a RS 232 plug ) with an USB adapter to the computer, downloaded the software what is mentioned here, installed the software, adjusted to COM 2 ( USB ) and there was nothing happened. no scope picture, but when I click on " save plot values " and later have a look at there are several numbers. from 0 to 255, then behind this sign " = " and then behind all 129.
example:
Trigger=
Hold=
Memory=
AC/DC=
Probe=
0=129
1=129
255=129
so something has been transfered. but there is no grafic to see.
what is wrong?
I made those settings:
Baud rate = 57600
Parity bits = none
Stop bits = 1
Data bits = 8
DTR = disabled
RTS = enabled
No handshaking, no flow control
any help would be appreciated
thank you
You will need to enable PC communication (Menu > Screen > Send)
Please view the “PC interface” chapter on page 60 of the user manual:
velleman.eu/downloads/0/user … 0_rev1.pdf
