I’ve buyed a PPS10 scope, but there’s a problem to connect it with VISTA.
With XP-PRO it works perfectly.
Many thanks in advance
Alessandro
Did you try running the software in XP-compatibility mode ?
Do you get any error messages ?
[quote=“VEL417”]Did you try running the software in XP-compatibility mode ?
Do you get any error messages ?[/quote]
Thanks for your reply.
I’ve tryed with xp compatibility but get same problem without any error message.
Note that I’ve installed Prolific USB to serial COM drivers ( Lastest version 3.0.0.0 dated 01/02/2007 ) and didn’t any problem with other SW that use serial COM.
Regards
Alessandro
