Hi I have just assembeld the 4005B kit, and was wondering if I can us a 800Va transformator? Im planing to biamp and use two is its works okey.
I think the output is about 40V but im gonna check that later today.
Regards
Henning
Regards
Henning
sorry, it was posted under PC related projects.
Be careful:
The K4005 requires a different supply voltage for each confinguration (2 x 8 ohm, 2 x 4 ohm or 1 x 8 ohm)
2 x 30VAC is the absolute max transformer voltage !
For 4 ohm or bridged operation, it is only 2 x 21VAC !
Okey then I have checked the voltage, on the primary its 51V and on the secondary its 31V.
Are there any way to make it handle 51V?
I’m afraid not…
