Power to control board but no movement on motors.(15.30V)
Shows connected and that the extruder and heat bed gain temp but don’t get hot. Can touch with bare fingers. Motor controllers show no voltage either.
Rolling Thunder
What do you see in the log area after you press connect in the software.
Check the Baud rate, it should be set to 250000
If this is correct press the reset button on the control board.
If is responds after that then go into the printer settings.
Under the connection tab make sure the “Reset on Connect” is set to “Disabled”
Hope this helps.
start
firmware_name : repetier virtual printer firmware_url:https://github.com/repetier/repetier-firmware/protocol_version:1.0~~~~
n1 m220 s100 *64
n2 m221 s100 *66
n3 m111 s0 *66
n4 m105 *3
n5 m105 *2
n6 m105 *1
n7 m81 *61
n8 m105 *15
n9 m105 *14
n10 g91 *0
n11 g1 x-10 f4800 *6
n12 g90 *3
n13 m105 *53
Still no motor movement or heat being generated by either the extruder or heat bed.
Rolling Thunder
NY State USA
Hi Rthunder,
you connect to the “wrong” printer, Repetier Host has a virtual one preinstalled for testing puposes. Click the small triangle right next to the connect button to select the printer.
Cheers,
kuraasu
