does the PCGU1000 also work without power supply from USB power?
Marcus
Marcus
The PCGU1000 is optically isolated from the PC.
This is why the external power supply is needed.
Optical Isolation is a great news.
Can one connect a power supply to the unit which fulfills the EN 60601 norm so that the PCGU1000 can be used to apply frequencies to the human body?
Marcus
[quote]Can one connect a power supply to the unit which fulfills the EN 60601 norm so that the PCGU1000 can be used to apply frequencies to the human body?[/quote]The power supply of the PCGU1000 is a standard 9V DC adapter, 600mA.
You may replace it with the supply fulfilling the EN 60601 norm.
There is only basic insulation between the PCGU1000 and the PC. This insulation is mainly made to protect the PC in case if the output of the PCGU1000 is connected to a voltage.
Fine. So do you think if we replace the power supply by a EN 60601 device and also seperate the USB with a EN 60601 4kV isolator and put both devices together in an additional plastic box, the whole device could possibly fulfill the EN 60601 norms to apply frequencies to the human body via handelectrodes?
I mean just from the point of view of of electrical security.
Or do you see any other potential problem we have to solve?
Marcus
[quote]So do you think if we replace the power supply by a EN 60601 device and also seperate the USB with a EN 60601 4kV isolator and put both devices together in an additional plastic box, the whole device could possibly fulfill the EN 60601 norms to apply frequencies to the human body via handelectrodes?[/quote]Based on my understanding, this solution fulfills the EN 60601 requirements if the 4kV isolator fulfills the double or reinforced insulation.
Here seems to be one such isolator:
bb-elec.com/product_family.asp?FamilyId=651
Great. And good price also.
