I have noticed that my last two prints have had problems with the plastic. When it draws the shape around the printed object, no plastic is coming out of the printhead until the very end. Also, as the printhead is printing, sometimes there are small blobs of plastic mixed with continuous lines. It’s as if the printhead isn’t hot enough or the extruder is pulling the plastic filament back too far.
Hard to say what is going on.
A picture may help
If you are printing PLA the temp should be around 190.
It sounds like the hot end is to hot.
Check the position of the thermistor.
look at the filament tension, turn it up with the screw at the top of the extruder.
it will force the filament to get taken by the bearing and get a better unifrom pression.
also try to add thig Gcode command just befor the printing begins : G1 E10 F400 ; prime the nozzle
[quote=“xnordz”]look at the filament tension, turn it up with the screw at the top of the extruder.
let me know plz ![/quote]
Which line is the start of the print? Is there a way to identify it?
[quote=“stevemagicianful”][quote=“xnordz”]look at the filament tension, turn it up with the screw at the top of the extruder.
Which line is the start of the print? Is there a way to identify it?[/quote]
hi sorry for the delay.
here s an example of my G code
G21 ; set units to millimeters
M190 S60 ; wait for bed temperature to be reached
G28 ; home all axes
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
M109 S245 ; wait for temperature to be reached
G92 E0
G1 F3900.000 E-3.00000
G92 E0
G1 Z0.300 F15000.000
