- Objects REALLY sticking to bed
Be careful what you ask for !!! Originally I had problems getting items to stick to the bed
Now I am having a problem that the PLA items I print are stuck REALLY hard to the bed.
I have to peel the masking tape off the bed to get the item off and sometimes the tape actually tears around the object and the objects stays stuck to the glass (through the tape)
I use a 50 degrees c heated bed with Velleman tempered sheet of glass and the blue masking tape
At the moment (starting) I am printing trolley euro coins for testing so they are quite thin (approx 2.5mm) and they are hard not to damage when removing from bed.
Any suggestions (less bed heat ?)
I have just fitted the K8204 Zaxis upgrade provided by Velleman (and subsequent firmware upgrade) but I don’t think this is the issue above
All my object dimensions are pretty much 10% off when printed and compared to original drawings (both W X H).
I am disappointed the Zaxis upgrade didn’t at least fix height issues.
Any pointers how to go about fixing this ?
Mods
Precise Z-Axis Home Calibration V1 thingiverse.com/thing:317411
K8204 Velleman 3D Printer Z-Axis Modification theelectronicsshop.co.uk/con … k8204.html
3D Printer Glass Plate GP8200
3d Printer ring light
