I bought my K8400 at Christmas and I’ve been using it intermittently since then with the filament more-or-less permanently loaded. I’m maybe 2/3 of the way through the 1st Kilo spool of PLA. A few days ago I came across this http://3dprintingforbeginners.com/how-to-store-3d-printing-filament/ and started looking up further details. I then unloaded the filament and put the spool in one of the vacuum bags mentioned. Today I also noticed that a couple of filament offcuts I’d left lying around had become very brittle and snapped easily.
Yesterday I reloaded the filament and it took 2 attempts - the first load didn’t work so I unloaded and tried again. After a few seconds of clicking extruder it made it through and I printed a couple of very small things. Then I tried a 20+mm cube as a test (I’ve switched to Simplify3D so wanted to calibrate). I noticed a few black specks in the plastic during printing, then after about 10mm the filament tube started shaking and there were some strange noises. I noticed the top surface was no longer smooth and the was sort of ‘fluffy’. I think the filament wasn’t being extruded smoothly. I stopped the print unloaded the filament.
I will start next time with a new spool, which is still packed, assuming it will load, maybe I have a blockage somewhere.
Has anyone experienced problems with PLA & moisture? Could my experience be explained by that? Should I unload the fiilament and store the spool when I’m not printing for a few days? The humidity where I have the printer is around 44% at the moment, but it’s been in other rooms and we’ve had a lot of snow & rain recently so probably days with higher humidity.
I’d be grateful for some tips.
John
