hello,
I want to use the PIR415 to switch on each light separately in a large small corridor of 35 meters length with 11 led-lights at each door. I tried this out with 1 PIR415 in each light but that doen’t work that good. I could build in 2 sets of PIR415, than it work perfect but that will be a very expensive thing to do.
So my question is: is it possible to buy extra sensor’s for the PIR415, and will it work if I connect them parallel to the 1 connector of the controller?
greetings, Ronny
