Thank you for your response…
But i have this message :
09:00:04.561 : PID Autotune failed! Temperature to high
09:00:04.561 : ok
But it is a good function !
Patrick Levesque
(c’est un peu bête de se parler en rosbif entre français).
J’ai trouvé la commande pour le réglage automatique du PID dans le microcode du contrôleur, que l’on peut ouvrir avec Arduino.
Ci-joint le copié-collé des codes de commande (tout est en rosbif) :
Implemented Codes
G0 -> G1
G1 - Coordinated Movement X Y Z E
G4 - Dwell S or P
G20 - Units for G0/G1 are inches.
G21 - Units for G0/G1 are mm.
G28 - Home all axis or named axis.
G90 - Use absolute coordinates
G91 - Use relative coordinates
G92 - Set current position to cordinates given
RepRap M Codes
M104 - Set extruder target temp
M105 - Read current temp
M106 - Fan on
M107 - Fan off
M109 - Wait for extruder current temp to reach target temp.
M114 - Display current position
Custom M Codes
M80 - Turn on Power Supply
M20 - List SD card
M21 - Init SD card
M22 - Release SD card
M23 - Select SD file (M23 filename.g)
M24 - Start/resume SD print
M25 - Pause SD print
M26 - Set SD position in bytes (M26 S12345)
M27 - Report SD print status
M28 - Start SD write (M28 filename.g)
M29 - Stop SD write
M30 - Delete file on sd card
M32 create subdirectory
M42 P S<value 0…255> - Change output of pin P to S. Does not work on most important pins.
M80 - Turn on power supply
M81 - Turn off power supply
M82 - Set E codes absolute (default)
M83 - Set E codes relative while in Absolute Coordinates (G90) mode
M84 - Disable steppers until next move,
or use S to specify an inactivity timeout, after which the steppers will be disabled. S0 to disable the timeout.
M85 - Set inactivity shutdown timer with parameter S. To disable set zero (default)
M92 - Set axis_steps_per_unit - same syntax as G92
M112 - Emergency kill
M115- Capabilities string
M117 - Write message in status row on lcd
M119 - Report endstop status
M140 - Set bed target temp
M190 - Wait for bed current temp to reach target temp.
M201 - Set max acceleration in units/s^2 for print moves (M201 X1000 Y1000)
M202 - Set max acceleration in units/s^2 for travel moves (M202 X1000 Y1000)
M203 - Set temperture monitor to Sx
M204 - Set PID parameter X => Kp Y => Ki Z => Kd S Default is current extruder. NUM_EXTRUDER=Heated bed
M205 - Output EEPROM settings
M206 - Set EEPROM value
M220 S - Increase/decrease given feedrate
M221 S - Increase/decrease given flow rate
M231 S<OPS_MODE> X<Min_Distance> Y Z F - Set OPS parameter
M232 - Read and reset max. advance values
M233 X Y - Set temporary advance K-value to X and linear term advanceL to Y
M251 Measure Z steps from homing stop (Delta printers). S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
M303 P<extruder/bed> S Autodetect pid values. Use P<NUM_EXTRUDER> for heated bed.
M350 S X Y Z E P : Set microstepping on RAMBO board
M400 - Wait until move buffers empty.
M401 - Store x, y and z position.
M402 - Go to stored position. If X, Y or Z is specified, only these coordinates are used. F changes feedrate fo rthat move.
M500 Store settings to EEPROM
M501 Load settings from EEPROM
M502 Reset settings to the one in configuration.h. Does not store values in EEPROM!
M908 P S : Set stepper current for digipot (RAMBO board)
