The configuration bits has to be set properly in the compiler, right ? If they are set in the compiler then no need to select in PicProg2009 ? Is this means we need to un-check all these configuration bits in the PicProg2009 if teh configuration is done in compiler ? Do we also not need to select the Oscillator ?
