I am a happy owner of a Velleman 8020 valve preamplifier.
Recently, I have purchased a turntable and would like to hook it up to my existing system Hi FI system.
Would it be possible to modify/change one of the AUX/AV inputs to a phono (MM) input?
If no, then perhaps you have a solution/or do your offer a dedicated phono (MM) preamplifier which “works” with the 8020?
Sorry, modifying an input is not possible.
Basically, you can use any phono pre-amp which outputs a line level.
As a kit, we offer the K2573.
Hint: to avoid hum problems, run the unit from two rechargeable 9V batteries and mount it in a separate enclosure, not inside the K8020.
http://www.velleman.eu/products/view/?id=8985
Thank you!
What is the price of the K2573? What would be the total cost: K2573 + transport to Poland?
Do you sell it in a “enclosure”?
As i am NOT an electrician, how to “insert” it into the turntable > 8020 audio path?
Sorry, we do not sell direct.
Furthermore, if you do not have any experience, we do not recommend to use this device.
As we do not carry a fully functional assembled phono stage, we recommend to get a unit from a third party.
Thank you for the clarification, even if it is no good news for me.
