PE filament & AutoDesk Inventor
@VELLEMAN
Maybe a silly question! Does PE filament exist and if so can it be used with the K8200?
@anyone
Does anyone know whether the output file from the 3D Design Tool “Autodesk Inventor” can be used with or without conversion to stl format. If conversion is required how can I do that and with what?
I do not know Autodesk Inventor but I received a request to print stuff generated with this tool on the K8200.
Your help is very much appreciated!
thanks
I think Inventor can export to .STL
(youtube.com/watch?v=BJlvCsAb2BU)
Yes, Inventor can export to STL.
Yes, you can export to stl. Go on Export than CAD-Format. In the next Window choose the .stl Format.
Look in Options that the Unit is right, mm or cm or what you want. If it is not right the scale ist wrong.
