According to the driver and software.
Error message: Found driver, but error in installation. The required section was not found in the .inf file.
Windows 7 Professional 6.1.7601 Service pack 1 Build 7601 64 bit.
Error also in test mode.
On 64bit Windows you have to disable the driver signature enforcement to install the driver:
- During booting your PC/Laptop, press “F8” key continuously to access the “Advanced Boot Options”
- Use the “Down” arrow key to scroll down to “Disable Driver Signature Enforcement”
- Press “Enter” to choose
- It will automatically reboot disabling the enforcement.
Now you should be able to install the driver.
After the next computer restart the driver signature enforcement is no longer disabled but you can run the PCSU200 normally.
