I just bought a PCSU 200 from you. Unfortunately Windows was unable to find the driver to install it.
I looked on your site but could only find a driver for Windows 8. I am running Windows 7. Could you let me know what to do?
The drivers will work on Windows 7
You can download them from this link.
http://www.vellemanusa.com/support/downloads/?code=PCSU200
After you unzip them there will be instructions in the folder to help you install them.
Hi, I have bought the PCSU200 and are not able to install the driver.
Win7 SP1 64.
It says …missing information in .INF file
Velleman use to have instruction in the download section for the PCSU200 but it’s gone.
Here are some screen shots.
Did you use the latest software Rev 1.07 for the PCSU200 ?
It contains the driver install too.
Available here: https://www.velleman.eu/support/downloads/?code=pcsu200&type=
If still not working, you can download the Windows 7 driver here:
https://app.box.com/s/br3hkbsr13jgwbtx1nrrh5p09bucbjtn
In 64 bit version of Windows 7, you have to disable driver signature enforcement to install the driver:
Press F8 when Windows is booting up until you get the Advanced Boot Options menu, then select “Disable Driver Signature Enforcement”.
