I am trying to install pscu200 on my xp sp3 computer. PCLab installs nicely, but when trying to connect the oscilloscope there are problems. The Guide for installing hardware kicks in, but fails to find anyy drivers for the pcsu200, both automatically and manually - the manual approach fails to give a browse option. What, if anything, can be done to resolve this? As of now, the software cannot connect to the hardware and there are no specific driver files visible to med when I explore. I have downloaded the 1.05 version.
I found this in another thread.
You should install the USB driver for the PCSU200.
The downloaded installation package contains the instructions document: “PCSU200 Driver Installation.pdf”.
Hope this helps.
The instructions in the document ‘PCSU200 Driver Installation.pdf’ are for Windows 7.
Windows XP installation is slightly different.
For more info please see: pcsupport.about.com/od/fixthepro … iverxp.htm
Here are the instructions:
When the Hardware Update Wizard appears:
To the “Can Windows connect to Windows Update to search for software?” question, choose the No, not this time radio button and then click the Next > button.
To the “What do you want the wizard to do?” question, choose the Install from a list or specific location (Advanced) radio button and then click the Next > button.
The next window that appears will be the Please choose your search and installation options. window containing several radio buttons and checkboxes.
Choose the Don’t search. I will choose the driver to install. radio button and then click the Next > button.
Click the Have Disk… button on the Select the device driver you want to install for this hardware. window.
Click the Browse… button on the Install From Disk dialog box that appeared.
In the Locate File dialog box that appears next, navigate to the driver folder:
C:\Program Files\Velleman\PcLab200\PCSU200Driver
Click the INF file that displays in the file list and click the Open button.
Note: Device Manager only reads INF files so you won’t be able so select anything else. If you run in to trouble here, see the Tips at the bottom of this page.
Click the OK button back on the Install From Disk dialog box.
Choose the newly added hardware back on the Select the device driver you want to install for this hardware. window and then click the Next > button.
If you’re warned about the software for the hardware device not passing the Windows Logo testing, click the Continue Anyway button.
The Hardware Update Wizard will now use the instructions provided in the INF file from Step 11 to install the updated drivers for your hardware. Follow any additional instructions on screen to complete the driver update.
For even more info: youtube.com/watch?v=7aHc9KegDAc
Thanks a lot! Now the software finds the hardware.
