Hey,
I’m working on doing measurements with the PCSU200 in python but struggling with saving the data via
ReadCh1(Buffer: Pointer)
I’m not that into ctypes. Maybe someone has a solution for me?
Currently I have something like
cresult = (ctypes.c_ulong * 5000)()
data_1=PCSU200dll.ReadCh1(cresult)
But yeah, that doesn’t work
VEL255
2
Indeed, not very easy in Python…
I got finally this working:
print("Read Ch1 values")
arrayType = ctypes.c_long * 5000
ch1 = arrayType()
PCSU200dll.ReadCh1(ctypes.byref(ch1))
print("Print 10 first Ch1 values")
for x in range(10):
print(x,"=",ch1[x])
VEL255
3
Also this seems to work fine.
Here the only difference with your original code is the added “ctypes.byref”.
ch1 = (ctypes.c_ulong * 5000)()
Thank you so much!
You don’t happen to know how to save DataReady from the dll as a proper boolean in python?
VEL255
5
The function DataReady() seems to return ‘0’ (False) or ‘1’ (True):
You can use bool() method to convert it to boolean:
b = bool(PCSU200dll.DataReady())
print ("Data ready =", b)
