PCSU200 Read out Waveform parameters
is there a way to read out the Waveform parameters with the help of pcsu200.dll?
If not, is it then possible to adjust the dll to be able to read out the waveform parameters?
Thanks Frank
I’m sorry, there is no such option to read out the waveform parameters with the pcsu200.dll.
Also at the moment there are no plans to add this option to the dll.
As a workaround in the oscilloscope mode you can print the parameters (to file) or save them as a picture.
To print the prameters:
In Options menu select “Waveform parameters”
Select the parameters to display
In File menu select “Print Setup”
Select Orientation Portrait
Then select File -> Print
If you have printer option to print to file (eg. to PDF), you can get the waveform parameters in text.
To save the parameters as a picture:
Select the check box “Show on Screen”
In File menu select “Save Image”
If you’re able to do a bit of coding have a look at this forum post.
