we do have a customer that purchased the PCSU200 Oscilloscope and after an OS upgrade to Windows 10 we are facing problems with the present hardware and its driver.
Can you possibly provide an updated driver for Win10 x64 to us or any kind of documentation how to get the driver running?
You can use the current driver supplied together with the software.
If the PcLab200 software is installed to the default folder, you will find the driver in the folder:
C:\Program Files (x86)\Velleman\PcLab200\PCSU200Driver
On 64bit Windows you have to disable the driver signature enforcement to install the driver.
Here you’ll find the instructions how to disable driver signature enforcement in Windows 10: howtogeek.com/167723/how-to- … d-drivers/
After the next computer restart the driver signature enforcement is no longer disabled but you can run the PCSU200 normally.
