Hello!
I’ve got a problem. It’s shown on the picture.
Is it possible to repair my device by flashing it via USB with a standard firmware or somehow else?
A workaround may be to run the calibration in other PC and copy the PCSU200.INI file from the other PC your PC.
The file PCSU200.ini is located in the folder:
in Windows Vista, Windows 7, 8, 10:
C:\Users<username>\AppData\Local\Velleman\PCSU200
in Windows XP:
C:\Program Files\Velleman\PCSU200
Using an external self powered USB HUB may help too.
Please see also these threads for possible solution:
viewtopic.php?f=10&t=8916
viewtopic.php?f=10&t=11055
If no help, you can return the PCSU200 for repair via your local Velleman dealer or direct to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
Nothing helped…
I used to read all the related topics, but my device still can’t calibrate itself.
My proof document of buying is http://www.clamber.ru/mydevice.pdf
Can I use your guarantee and send the device from Russian Federation to Belgium?
[quote]Nothing helped…
I used to read all the related topics, but my device still can’t calibrate itself.[/quote]I’m sorry for the inconvenience.
[quote]My proof document of buying is clamber.ru/mydevice.pdf
Can I use your guarantee and send the device from Russian Federation to Belgium?[/quote]For more info about the warranty please see: velleman.eu/support/warranty/
