PCSU200 broken firmware?
Hi at all,
Since this week i have a little problem.
My device is a PCSU200 digital oszilloscope.
I have programmed a microcontroller with my new programmer for microcontrollers. In the IDE of the programming tool, i have chosen the wrong port by accident. I think that has destroyed the firmware of my pcsu200.
Now i want to know, how i can update the firmware of the pcsu200.
Can someone help me to handle this?
Yours sincerely
kleinerkaktus
(I´m sorry for bad englisch. It´s not my first language. :wink: )
That should not destroy the firmware.
Please try following:
Close the PcLab200 software if running.
Disconnect and reconnect the USB cable of the PCSU200 .
Run PcLab200 software.
thanks for your answer.
I have already tried this. Now I´ve seen another Problem. The software-driver had a problem.
I have reinstalled it, but it doesn´t help. MS-Windows says that everything is fine.
I don´t know what I can do. Do you have any ideas?
When the PcLab200 is run, is there message “No hardware response…” displayed?
Doesn’t the USB cable disconnect/reconnect → run PcLab200 again help?
What version of Windows are you using.
Hi, yes there is a message like this. It also says that the software is running in demo mode.
I´ve already done this.
Ah heey, now it´s running…
Don´t know where the problem was, but it´s working.
Tried it a few times and after the fifth try it is doing its job well.
Nice to see that everything is back to normal now.
