There are 3 ground connections: CH1, CH2 and OUT
Are they internally connected? (Is it enough to connect only one of them to the ground of the circuit under test?)
Or not? (Can I connect CH1 ground to “-” of power supply and CH2 ground anywhere in the circuit e.g. to measure voltage drop across a single resistor?)
Thanks a lot!
