Hi. I wonder how can I measure voltages more then 30V?
Can I use the included probe for this? This is not directly fixed in the manual to my mind.
To measure higher voltages you have to change the slider in the probe to position x10. When done, the probe is set to attenuate the signal by 1:10.
In the oscilloscope interface click the button x10 (next to the text ‘Probe’) to get proper readings.
When using the probe’s x10 setting, you have to adjust the probe compensation to get good frequency response.
Please see also: viewtopic.php?f=10&t=7547
OK. Thanks a lot
