In AC mode, sometimes the offset voltage level doesn’t remain the same when changing the voltage selector. It occurs only in CH1.
Is there a bug ?
Is there a bug ?
It is normal that there may be trace jumps about one small division on the screen.
Select Options menu and click Calibrate - it may help.
The trace jump could be more than one division.
However thank you for the tip. We are going to try with calibrate operation.
