You may first check the USB driver is installed and working OK.
In the Device Manager under Universal Serial Bus controllers double click PCSU1000_Oscilloscope.
Under Driver tab check the driver version is 2.4.16.0.
Under Details tab select Property: hardware Ids.
There should be seen:
USB\VID_10CF&PID_1000&REV_0400
You may use USBView to check more details.
Also you may use FTProg.exe and MProg.exe from FTDI to check and to re-program the PCSU1000’s EEPROM if corrupted.
