PCSU1000/PCGU1000/PC-Lab2000SE
Please give me detailed instructiones !!!
How can I install PCSU1000 / PCGU 1000 / PC-Lab 2000SE with 64-bit Windows 10?
Where can I find functioning drivers for 64-bit Windows 10.
(It works correctly with 32-bit Windows 7 but I can’t install it under 64-bit Windows 10)
To install the driver you have to disable the driver signature enforcement.
You can use the latest drivers.
In case of the PCGU1000 please follow the instructions in the chapter “1.3 Workaround to use the PCGU1000 on 64-bit Vista or Windows 7” of the Release Notes.pdf.
Here you’ll find the instructions how to disable driver signature enforcement in Windows 10:
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
I did all like you said !!
PC-Lab2000SE is running correct.
Now PCSU1000 is running correct.
PCGU1000 is only running, if I start Win10 with “Disable Driver Signature Enforcement”
What can I do to run PCGU1000 in normal operating mode ???
