I have a PCSU1000 Oscilloscope which was functioning well
up until a few days ago. Running on 32 bit Windows XP sp3.
No drops, no accidents, simply started giving me problems.
Here is what happened every time i opened it up–
<>----open PCLab200SE------
prompts me with
“Other PCSU1000 software may be active.
Simultaneous use will cause problems.
Run anyway?”
-clicked “yes”-
after a few successful minutes of measuring,
FT_Write - General IO Error (clicking “ok” brings the following up)
GetFTDeviceSerialNo - Invalid Handle. (clicking “ok” brings it up again)
since it is locked up, i have to close it with the task-manager
upon re-opening PCLab200SE
I`m prompted with
Run anyway?”
But there are no other instances of PCSU1000 software running.
------go back to beginning and and repeat — <>
So, I decided to update the software and the drivers from the website.
I updated to pclab2000se_v4_03
pcsu1000_driver_2_04_16
and also the CDM20814
the device manager wont let me update the ftd2xx.sys file from the download. it only finds that file on the disk that came with the product. could this be the problem? why wont it work to update the ftd2xx.sys file
from the Velleman driver download? I have uninstalled all PCSU drivers from
the device manager, and chose the location of new drivers in the pcsu1000_driver_2_01_16
folder which i made and put the downloaded contents into----but it can`t seem to see them or find them…it askes specifically for the
pcsu1000 disk from an external drive and for the FTD2XX.sys file. (notice the large case letters) and only finds it on the disk that came with the product, (velsoft 2.0).
Could someone please give me an idea of what is going on with my oscilloscope?
and ideas would be greatly appreciated. And further, why can`t I successfully update the
ftd2xx.sys file which seems to be working no further with my system.
Also of note, after updating the drivers, the program Calibrates upon every open.
help, please.
