I have pclab2000se_3_08 and latest pcsu1000_dll_package. When I call GetSettings from my program it doesn’t change anything in array provided.
I also tried Velleman’s examples written both in Delphi and VB with same result. GetSettings just don’t retrieve any settings.
What is the problem and how to solve it. Thank you.
To get all the DLL functions work correctly the PCSU1000 have to be run from within the application program.
Please use the Start_PCSU1000 function.
If you get “I/O error 103” then you have to copy the pcsu1000.bit file from the \Program Files\Velleman\PC-Lab2000SE folder to your application’s folder.
