Hi I have problem with my PCSU1000. It is connected to the PC all the time but my last project includes FTDI245BM onboard so in process of developing probably I had erased the eprom atached to FTDI245BL in my PCSU. Now it does not work. I tried to connect it to another PC and then I saw what driver was installed. So I read the content of eprom by MProg3.0 :
… … … .F .T .D .I …
.U .S .B … .S .e .r .i
.a .l … .C .o .n .v .e
.r .t .e .r … .F .T .D
.W .H .5 .5 .7 … … …
Next I wrote 10cf as VID and 1000 as PID and I managed to install the driver for PCSU on the PC but when start Pc_Lab2000 there is error message: Open USB device by serial number - Device not found. I do not know what is the serial number of my PCSU - on the back is written 200701285 but in filed for SN in MProg should be eihgt digit number and when I try to write SN at the end of programming I get message that SN is disabled. Could you help me with my SN and how should I write it.
Regards
The serial number is YEL952TL.
Here is the content of the setup file (.ept file) for the PCSU1000.
[Basic Details]
Device Type=4
VID PID Type=2
USB VID=10cf
USB PID=1000
[USB Power Options]
Bus Powered=1
Self Powered=0
Max Bus Power=490
[USB Serial Number Control]
Prefix=
Use Fixed Serial Number=1
Fixed Serial Number=YEL952TL
[USB Remote WakeUp]
Enable Remote WakeUp=0
[Windows Plug and Play]
Enable Plug and Play=1
[USB String Descriptors]
Manufacturer=Velleman
Product=PCSU1000
[Programming Options]
Only Program Blank Devices=0
[BM Device Specific Options]
USB Version Number=1
Disable Serial Number=0
IO Pin Pull Down in Suspend=0
Enable Isoch IN Transfers=0
Enable Isoch OUT Transfers=0
Copy and paste this text to some .ept file and open it to MProg. Erase and re-program the EEPROM. You’ll get all the factory settings restored and your PCSU1000 should be OK again.
Thank you very much for your help - my PCSU1000 is running again!
Thank you!
