Hi
I am using PCSU1000 under an MS Windows 7 environment and I am experiencing application hangs when switching between run (continuous) and single (single shot) modes.
Does anyone have similar application behavior?
Any hint?
Thank you.
Hi
Any hint?
Thank you.
[quote]I am experiencing application hangs when switching between run (continuous) and single (single shot) modes.[/quote]Can you avoid this to happen if you first stop the Run and then click the Single button?
Yes, I can.
Since I am proceeding as you said, I haven’t had the problem again (yet), i.e. no hangs.
Thank you.
In the latest software version 4.02 this problem is fixed using this workaround:
Hello VEL255,
Where can one get this version 4.02? Under PCSU1000 info page the only proposed version is 4.00 (date early 2010).
Regards
Here is the link to download the updated PcLab2000SE software v4.02: velleman.eu/downloads/files/ … _v4_03.zip
Please note:
If you are using Windows Vista, delete the file [color=#000080]pcsu1000.bit[/color] from the folder:
C:\Users<UserName>\AppData\Local\VirtualStore\Program Files\Velleman\PcLab2000SE
If you are using Windows 7, delete the file [color=#000080]pcsu1000.bit[/color] from the folder:
C:\Users<UserName>\AppData\Local\VirtualStore\Program Files (x86)\Velleman\PcLab2000SE
By doing this, the new installed pcsu1000.bit file will take effect and the new features of the oscilloscope are usable.
Thanks a lot.
May I ask why this is not made available directly from the PCSU1000 information page (under download section)?
Regards
The v4.00 is the only “official” version at the moment.
The version 4.02 is still a development version.
Anyhow, will be available soon on the Web site…
I see. Thanks for explanations.
I just installed v4.02 above v4.00 without any problem on my system (Win 7 Pro 64 bits). But I just want to comment the following:
a) pcsu1000.bit file was/is not present in the designated folder - neither before installation of v4.02, neither after installation.
b) v4.02 still behaves like v4.00 on the following:
b.1) Endless loop of popup windows when starting PCSU1000 program while the PCSU1000 oscilloscope is not connected to the USB bus. Only way to get out of this situation is to kill the program via the Task Manager. While I recognize this is a normal situation, the program should probably exit gracefully instead of this endless loop.
b.2) If the program has not run as Administrator, at least once, the calibration process does not complete successfully (log file does not contain any error message). Calibration process run up to 100% but then an error windows pops up, indicating the calibration process couldn’t complete. This behavior disappears if the calibration process is completed as an administrator (one time).
Thank you for your comment. This is valuable information for the next release version of the PcLab2000SE.
[quote]a) pcsu1000.bit file was/is not present in the designated folder - neither before installation of v4.02, neither after installation.[/quote]Have turned off the User Account Control (UAC)? If yes, it is the reason why there is no .bit file in the “VirtualStore” folder.
In Windows Vista it should be there anyhow. Please see “File System and Registry Virtualization” and “Virtualization Example” in this article: zone.ni.com/devzone/cda/tut/p/id/5538
[quote]b) v4.02 still behaves like v4.00 on the following:
b.2) If the program has not run as Administrator, at least once, the calibration process does not complete successfully (log file does not contain any error message). Calibration process run up to 100% but then an error windows pops up, indicating the calibration process couldn’t complete. This behavior disappears if the calibration process is completed as an administrator (one time).[/quote]Normally the PCSU1000 goes to the demo mode if the USB cable is not connected.
Hello again,
Under Win7 the UAC is more relax and I do not remember having modified anything on the security aspects of this program (not even run as administrator).
Otherwise I do confirm that when the PCSU1000 is disconnected and I start-up the PCSU1000 program, I get an endless loop of Error popups with the message
“Open_USB_Device_By_Serial_Number - Device Not Found.”
As soon as I connect the PCSU1000, the popups loop ceases but the program does not respond. Need to kill it.
No Demo mode.
Now the PCSU1000 software is updated.
The USB detection is improved.
Here is the link to download the updated PcLab2000SE v4.02.1: (removed)
Just installed it. Works OK, now the program switches to Demo mode.
But… I discovered an other issue which is not related to the USB connection.
It concerns the logic of activation/deactivation of the Run/Single buttons.
Both buttons get reactivated when Running if you check/uncheck the Logic Analyzer checkbox.
Try this:
Forgot also this one…
There is no difference in behaviour between File-> Exit and File-> Exit to Menu.
Both makes the program fully exit.
Thank you for the comments.
Now the two issues are fixed.
Here is the link to download v4.02.02 of the PcLab2000SE: (removed)
Just installed v4.02.2; The issue with the Run/Single buttons is effectively resolved.
But for the second issue, I’m not seeing any change - still no exit to PCLab2000 start menu, but full exit to Win 7.
Sorry - the “Exit to Menu” doesn’t work in the “Big Screen” mode yet…
Will be fixed in the “final” v4.02 release soon.
The PcLab2000SE version 4.02 is now ready.
Here is the link to download the software package: (removed)
The modifications are:
[color=#000080]PCSU1000 / PCGU1000:[/color]
Windows Vista and Windows 7 compatibility improved.
Added 1s/div range to oscilloscope.
Added 60Hz range to the spectrum analyzer.
Bode Plotter start frequency is now 0.1Hz.
[color=#000080]PCSU1000:[/color]
All the data and image files are now saved to the folder [color=#800000]Documents\My PCSU1000[/color].
Added possibility to invert the values for X and Y channels in XY-plot mode.
USB detection improved.
“Single” button disabled while running.
[color=#000080]PCSU1000, K8031, PCS100, PCS500:[/color]
“Exit to Menu” bug fixed.
(Me again; sorry for being so sticky)
Re-installed officiall 4.02
File Exit to Menu is now working either with Small or Big Screen.
But I’m unable to find the 1s/div range with my PCSU1000. Is that for an other model/version?
Mine is S/N 200701895.
Regards
The 1s/div range is for the combination PCSU1000 / PCGU1000.
You get it on by selecting both the PCSU1000 and the PCGU1000 in the startup screen.
