PCSU 200 Calibration problem
I,
I’ve got a PCSU 200 and i’ve got no signals.
Calibration results:
CH1 offset at 3V/div : 161 OK
CH2 offset at 3V/div : 161 OK
CH1 offset at 1V/div : 101 FAIL
CH2 offset at 1V/div : 101 FAIL
CH1 Y-position low 57
CH1 Y-position mid 58
CH1 Y-position high 58
CH2 Y-position low 58
CH2 Y-position mid 58
CH2 Y-position high 58
Is it possible to fix the problem?
You may try following to test if the oscilloscope is not defective:
If you have Windows Vista, Windows 7 or 8, locate the file PCSU200.ini in the folder:
C:\Users<username>\AppData\Local\Velleman\PCSU200
If you have Windows XP locate the PCSU200.ini in the folder:
C:\Program Files\Velleman\PcLab200
Open the file in any text editor and replace the file content with the following text and save the file:
[Calibration] offs_1=112 offs_2=116 v5_offs1=-4 v5_offs2=1 Ch1_pos0=127 Ch1_pos1=32 Ch1_pos2=224 Ch2_pos0=127 Ch2_pos1=31 Ch2_pos2=224 Ch1_ad0=111 Ch1_ad1=54 Ch1_ad2=169 Ch2_ad0=115 Ch2_ad1=57 Ch2_ad2=173 [Menu] HWdialog=0
Then run the PCLAB200.
The oscilloscope should work now OK without calibration.
viewtopic.php?f=18&t=8750
Thanks for the response
I’ve got the same problems with the new code. No signal
Have you got an other idea?
There may be either a compatibility problem or the PCSU200 is defective.
Can you test the oscilloscope in other PC?
If you have Windows 7 or Windows 8 you can download and update to the driver available from this page: velleman.eu/support/download … U200&type=
Download, extract and update the driver: “Driver for Microsoft Windows 8”
After the driver update please check in the Device Manager the driver version number is: 13.54.20.543
