Hi Everybody,
last days I bought a new PCSGU250. At old WinXP-System it works fine, but at my Win10-Computer the Driver Installation gets fail. Is there a new Driver for Win10 available?
Thanks very much.
Best regards
Wolfgang
Hi Everybody,
Thanks very much.
Best regards
Wolfgang
You can use the driver: “Drivers for Windows Vista and Windows 7. (Can also be used for Windows XP)” from:
velleman.eu/support/downloa … e=PCSGU250
Before installing the driver, you have to disable the driver signature enforcement.
Here you’ll find the instructions how to disable driver signature enforcement in Windows 10:
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
http://www.top-password.com/blog/how-to-disable-driver-signature-enforcement-in-windows-10-8-7/
disable the driver signature was the solution. Now it works.
Thank you very much.
Best regards
Wolfgang
Hmm, I have the same problem. I find it somewhat disturbing that you would have to circumvent safety measures to have the software run on modern operating systems. I would kindly suggest updating the drivers so that they are, in fact, compatible. A driver certificate can’t be a complicated thing to apply?
I am inclined to not hack my OS to make this work, and in such case I will end up not using the oscilloscope at all, but rather look for something else.
