Hi everybody,
I am using a PC generator PCSGU250 to generate some signals.
The goal is to generate a burst every 100ms during 2 second ( so 50 bursts) and then a pause during several second. And to repeat this signal.
I have write a lib file called onde.lib and i use it with the sequence genrator :
4 20 0 1 2.27 onde.lib
The lib file is a kind of ( 0,0,0,0,0,0,0,1,-1,0,0,0,0 )
The thing i don’t understand is : what correspond to frequency for this kind of library signal in the wave sequence.
For example if i set 20Hz in frequency field, does that mean that the entire library file will be read in 50ms, or each sample of the file is read in 50ms, or other ?
If someone have some technical information about this, i am very interested !!!
Cedric
