PCSGU250 Waiting for trigger
Hi
When I use the scope and press run I can see the wave updating and the at some time depending on my timing setting it stops and display waiting for trigger.
Is this correct or can you assist.
Johan Prinsloo
[quote]When I use the scope and press run I can see the wave updating and the at some time depending on my timing setting it stops and display waiting for trigger.[/quote]This should happen only if the trigger ‘On’ button is pressed.
