Hi, I was wondering if the source code for the PCSGU250 software (PCLab2000LT) is or could be made available. I am taking a class that requires use of this scope, but the software lacks some very useful features. For example, you can add or subtract channels, but not multiply them - and you cannot view a math function and a raw channel at the same time. I was hopeful that I could add this functionality myself with the dll that’s available, but that’s only for adding things external to the main executable. These additions should be relatively trivial, so I don’t want to end up making the entire program (which works well as it is) over again…
Maybe if the source isn’t officially available, an exception could be made if it’s licensed on a “research” basis to my academic institution (which should be a valued customer for buying a lot of these scopes)?
Any suggestions or confirmations of futility appreciated…
It’s nice that you like the PCSGU250.
Indeed, the PCSGU250 is a nice multifunction instrument and it’s ideal for educational purposes too.
Thank you for the suggestions to improve the software.
I’m sorry, but the source code is not available.
I would suggest the following approach:
Please specify all the modifications you like to have to the software.
The software will be modified according to your specifications (if ever possible).
You’ll get a link to download the modified version of the software for testing.
When complete, the modifications will be put to the next release of the PCLab2000LT.
