PCSGU250 open minimized
Hi
I have been running PCLab2000LT for some time. After one restart I tried to start it and it opened minimized. I can not get it to restore from the task bar.
If I Double click it nothing happens. If I hover over it the small version display showing the oscilloscope but nothing happen if I click on the small version.
This does not happen with any of my other programs.
Can anybody please assist.
Johan Prinsloo.
You can fix the problem by closing the PCLab2000LT and then deleting the file PCSGU250.ini in the folder:
C:\Users<username>\AppData\Local\Velleman\PCSGU250
In older PCs the file is located in the folder: C:\Documents and Settings<username>\Local Settings\Application Data\Velleman\PCSGU250
Then restart the PCLab2000LT.
Maybe the PCLab2000LT window was on the second display? - Now not connected or turned off…
viewtopic.php?f=10&t=3578
viewtopic.php?f=11&t=6952
I just edit the file top and left and Whalah!!
Johan
[quote]I just edit the file top and left and Whalah!![/quote]Indeed, you found an alternative solution!
