PCSGU250 No 'READY' light, won't calibrate
PCSGU250 DOA
Windows 7 x64 bit with lots of (available) resources.
Driver installed and is OK.
Finds and connects to PCSGU250 when the USB cable plugged in.
No Power/READY indicator light
Stalls at 0% complete when attempt to calibrate
I think you have downloaded and installed the latest software and the driver from:
velleman.eu/support/download … U250&type=
Most probably the problem is this:
The current consumption of the PCSGU250 is too high for your PC’s USB output.
The solution may be to use a USB HUB with external power adapter.
The current consumption of the PCSGU250 increases to about 400mA after the firmware is uploaded to the PCSGU250.
  • You see on the screen “Loading, please wait…” when the firmware is uploaded.
    See about Dell notebook PC’s USB current limitations: viewtopic.php?f=10&t=4658
In this thread there seems to be a software solution to enhance the power feed from the USB ports: viewtopic.php?f=10&t=8079
A complete shut down and reStart solved the problem.
Does the PCSGU250 still draw ~ 400 mAmps if the frequency generator isn’t running?
If not, how much does it draw?
[quote]Does the PCSGU250 still draw ~ 400 mAmps if the frequency generator isn’t running?[/quote] There is only minimal current consumption decrease if the frequency generator is off.
If the generator is overloaded (e.g. its output short circuited) the USB current ingreases to about 500mA.
