Pcsgu250 model oscilloscope
this is my first oscilloscope i have the pcsgu250 model when the program loads a message pops up and says that the maximum voltage between the probe and the ground is 30 volts and i thought that if i use a probe with a 10x 300 volts would be my maximum voltage but the message makes it sound like the 10x is irrelevant and im still limited to the 30 volts so i wont to make sure of what im doing could some one tell me which is it 300 volts with the 10x probe or am i still stuck with 30 volts even if im using a 10x probe
For safety reasons the maximum voltage is limited to 30V.
There is no problem to measure 300V with the 10x probe.
For more info please see:
viewtopic.php?f=10&t=7124
thank you! that what I wonted to know
