PCSGU250 instabilities software
Hi all,
I have a PCSGU250 and I use the PcLab2000LT (v1.09) software.
My PC is on 64-bit with windows 7.
I see several instabilities:
  • AutoSet does not work
  • To draw a Bode diagram, I have to restart several times for the total curves because it stops after a few values
Thank you for your answers.
Have you downloaded and installed the driver for Windows 7.
You can check the driver version in the Device manager:
The driver version should be 1.0.0.2.
If not, you have to download the driver.
Here is the link to download page:
velleman.eu/distributor/supp … U250&type=
Here you can download the detailed step-by-step instructions to install the driver: box.com/s/vh9olqyx3idhhxn8ujwm
Here are instructions how to update an existing driver if you do not remove it first:
box.net/shared/66aei7j31s
Thanks.
The difficulty was just to get around the plug-and-play in the device manager.
