PCSGU250 function generator with coil
I have pcsgu250 and want to experiment with coils and the function generator.
For example coils with 10, 20, 30 turns and different widths of the wire.
And then measure with hall sensor.
However, i’m not very experienced in electronics and want to be sure that will not damage the pcsgu250 module.
Any information in this direction like advises, examples, will help me.
Also, what is the minimum load for the generator output?
Thank you and nice evening!
[quote]However, i’m not very experienced in electronics and want to be sure that will not damage the pcsgu250 module.[/quote] Normally you don’t damage it. The generator’s output is short circuit protected.
The only way to damage the unit is to feed external high voltage to the function generator output.
[quote]Also, what is the minimum load for the generator output?[/quote]The minimum load is 0 ohms.
For more details please see also: viewtopic.php?f=11&t=5239
Thank you,
I started with the experiments and everything goes fine.
However, I made an op amp follower to not disturb the generated signal.
Have a nice day!
