I bought a new PCSGU250…
And was checking out the function generator…
I am trying to test… how do i test…
Do i touch the tip of my probe to the center , generator…
do I have to make a load, etc…
Currently i dont see the pule/waveform… it just gives me a line, at a voltage…
New to your unit, 2 hours and i search for set up, or test… so i cam to you.
How is the device configured?
Can you post a screenshot?
@VEL255 maybe you can answer?
Yes, by doing this you should see the waveform on the oscilloscope screen.
No load is needed.
Is the oscilloscope working properly?
As a quick test, touch the tip of the probe with your finger.
You should see some (50Hz/60Hz) noisy waveform on the screen.
looks like the unit… func gen does not work, out of the box… PCSGU250
how do you read the date of mfg code… serial number 201818354
just bought, and thought it might be a referb, or old stock, etc…
thank you
thank you vel337
thank you
